12V / 24V dual voltage alternator on a deuce
T
televisionman007
Guest
whats the ntotal cost and labor hours to add the second alt12v to a m109a3
DUG
Senior Chief/Moderator
73
Mesquite, NV
harleyrkc
Burton, MI
I love the idea of a 12/24 volt dual alternator but I couldn't find one reasonably priced when I looked. If someone knows where to buy one thats not $1800 like the one at Eriks, please let me know.
tim292stro
40
S.F. Bay Area/California
I know this thread is over two years old, but:
The AC terminal of an alternator (if expicitly provided) is a 12-pulse-per-revolution tach output. That's it. The load dump controller is simply a box that watches the Alternator revs and based on its setting, will dump non-critical loads if the alternator is not spinning fast enough to generate the power to support those loads + the critical loads. The tach output can also be used to drive, well - a tachometer. When set with the correct ratio (alt-pulley vs. crank pulley) the alt output frequency will indicate the engine RPM on an electrically signalled tach. I have a 200A C.E. Neihoff in my bus conversion (another forum I paticipate on), and I use the AC output for my tach.
