bguy193
- 3
- 18
- Farmersville,IL
Installed a circulating tank style block heater on the deuce and it works great. After plugged in for only two hours the heater hoses, intake, and top radiator tank were already pretty warm.
I mounted the tank to the pass side frame rail with the mount in the kit after tweaking it with a 180 deg twist. It is gravity fed (as specified in instructions) from the water pump housing where the lower heater hose is normally located. The lower, or return, heater hose was relocated to the water neck. The heated water, from the top of the tank, is plumbed to the intake manifold in the port that is usually plugged and not used. All this project took was a little time to figure out plumbing and a hand full of fittings. If you install one of these be sure to bleed the system of air before plugging it in or you will destroy the heating element.
Happy Trucking![Driver :driver: :driver:](https://www.steelsoldiers.com/images/smilies/driver.gif)
Happy Trucking
