I combined 12/24V systems on my previous M35. I ran three #6 wires from the battery box 0-12-24V points up to a 2-pole contactor and from there to a battery equalizer. The 0 was connected to the 0 terminal of the EQ and the other two were switched. The contactor had 30A/440V AC contacts intended to be used to energize motors, so it was more than sufficient to run 100A intermittently (some may argue but consider LRA locked rotor amps ratings).
The contactor solenoid was 24VDC and actuated through an ON-off-ON switch so that in one ON position the contactor was energized, and in the other ON position it was energized when the truck power switch was turned on. The cold solenoid terminal was simply connected to the 0 wire.
From the battery EQ terminals ran 12 gauge wires for 0/12/24VDC under the cab and up in front of the firewall so they could be accessed under the hood and then cone into the firewall for accessories (RT246, CB, GPS, aux dash lamps, cigar lighter, etc)
Also from the battery EQ terminals ran three #6 wires for 0-12-24 up into the S-280 shelter. The o wire was bonded to the shelter's DC system ground (this shelter had that). the 12 and 24 wires ran to the pair of 100A DC magnetic circuit breakers. Some will complain that #6 is too small for 100A, but the breaker is 100A and the load was no more than about 50-60.
From the other side of the 100A breakers, I distributed the 12V and 24V throughout the shelter. I set up a 12v and 24v set of breakers so that there was a 24V bus and a 12V bus.
To the busses could be connected (by more of these breakers) two sets of 12/24V AGM batteries rated 95AH, and through other breakers each individual piece of radio gear and other accesories in the shelter.
This way, many things could be done by turning on the appropriate breakers. Note these kind of breaker is usable as a switch. I also installed two regulated 12V 35A DC power supplies in series and set them to 13.65VDC so that batteries could be eternally floated on that source. Aslo of course they were the primary power for all the gear in the shelter.
1. use the truck to charge the shelter batteries
2. use external 120V with the power supplies in the shelter to charge the truck batteries, either bank of AGM batteries, or all
3. use the onboard generator to perform #2 above.
4. charge one set of batteries while using another
5. boost-start the truck by switching all AGM batteries and the truck's batteries onto the DC bus in an emergency
There are wiring diagrams and pictures of a couple of the black surplus 'rockwell collins' breaker panels of this at the link below. It shows what the breakers look like. These breakers can be bought surplus for $5-10 each in many Amp-ratings. This solution is far better than fuses and also better than thermal breakers and self-resetting breakers. It is very rugged both electrically and mechanically.
Last pint - -I soldered every wire connector and lug. Crimped then soldered. That is impotant. There was never any sort of issue and this was run for >5 years. The ultimate goal was safety and plenty of power.
This is perhaps more than most people want, but there is no need to build out more than you want. I hope the wiring diagrams and the pictures are useful.
M35 Commo Truck 23 June 2007 - Field Day" with the Irving Amateur Radio Club
