Cummins PT Pump Fits What???
fasttruck
636
Mesa, AZ
It appears to be a PT fuel pump but with some extra brackets for a governer or some such. They all look the same and the internal calibration determined how much fuel it meters and how hard the engine it is attached to runs. Could range from 220 to 400+ horsepower. If it it not marked then you will have to take it to a fuel guy and put it on a fuel metering bench to find out what it is.
Rene M
Houston, Texas
On that pump call any fuel shop and give them the cpl # on top of the tag of the pump and they will tell you by fuel code what it fits and a hp ratting.
That pump has a manual fuel shut off on it not a 12-24 volt solenoid. its a very strange pump. I have never seen one like it. It has a boost compensator on it so it is built for a turbo motor.
