dieck
- 0
- 0
- Austin, tx
Hi All,
I've had my deuce for about a week and am working my way through all the systems. I've found several air leaks I would like to resolve. It looks like most are around the "coupling nuts" referenced in the attached image from the service manual. I will probably need to replace some air lines and coupling nuts. Is there a standard specification for these items for an M-35a-2? Should I be looking surplus or is there somewhere I can buy them new?
Also I would like to cap off a couple that are leaking. Is there a screw on cap I can use to terminate an unused air connection? The previous owner bent the copper tubing but the leaks are before that at the actual nuts.
http://www.steelsoldiers.com/member...okup-picture13408-air-lines-coupling-nuts.gif
I did try to search but couldn't find a thread that addressed this although I must assume it is a common problem.
Thank you!
Heath
Thank you!
Heath
