cjkeeliii
- 4
- 0
- Thomasville, GA
I have an '85 m1008 and its cooling system is making me scratch my head. Here are the symptoms:
Used to run between 182 and 195 then began running around 205 so I replaced the radiator. Then it ran around 110 to 130 from late Summer throgh now until I found a leaky freeze plug (never could keep the overflow tank full) so I installed a block heater a couple of weeks ago. Still ran 110 to 130 until a few days ago and now it runs 160 to 165 but the overflow tank is full.
I don't get it: is the water pump broken? If the water pump works is the water even circulating if it never gets hot enough to activate the thermostat? For those that haven't installed a mechanical temperature gauge, let me tell you that I've run two different radiators and the temp will always cool about 5-7 degrees when stopped, and the temp will rise about five degrees on the interstate because of the heat from the road. Right now it's cold here in Georgia, so when summer comes I don't know how this thing will act. The radiator is the standard four row, brass, and copper model from O'Reillys'. The block heater is a 1000 watt Zerostart. As cold as the weather is now-38- this thing should be running 110 to 120. Any ideas? Thanks.
