Armor pictures from '68-'69
Ridgerunner
Holland, Mi
We went to my parents place last night to meet up with the rest of the family for Christmas. While there I came across some of his pictures from when he served in the military. He was in the armored division with the 82nd Airborn ('68-70) with the M551 Sheridan.
I figured I'd post the pictures up that I found, and share with Steel Soldiers.
rchalmers3
Half a mile from the Broad River
30
Irmo, South Carolina
Thanks for the images? I have a question regarding image #8: what is the purpose for laying out the rounds like that?
Rick
shootER
San Antonio, Texas
Rick
To more quickly load the rounds onto the tanks. Takes less time than uncrating the "tootsie roll" tubes and then taking the rounds out of those.
I served on M60A3s and M1IPs and have seen similar setups on the ranges that I used (though always on ammo docks, not on the ground).
rchalmers3
30
shootER,
How does the layout work? Does the tank do a slow roll along the arc of the layout and receive the rounds through the hatch via hand loading?
Sorry for the fundamental questions, I have zero mil and ammo handling experience.
rick
shootER
San Antonio, Texas
shootER,
rick
All the ranges I was on had a specific ammo "dock" (kind of like a heavy-duty loading dock) located behind and off to the side of the main firing line. When a tank crew completed firing their engagements, each tank went to upload ammo and offload empty shell casings there. The rounds were loaded by hand through the loader's hatch.
In the photos posted above, with the shells on the ground, it looks like maybe the crews took the rounds forward to the firing line where the tanks were.
rchalmers3
30
...... it looks like maybe the crews took the rounds forward to the firing line where the tanks were.
As in hand carry? Is that a normal procedure? Especially with those enormous, gray tipped projectiles of death??? Gawd, you guys were asked to do a lot!!!
Again, apologies from the unkowing.
Rick
shootER
San Antonio, Texas
Rick
The rounds didn't really weigh all that much (no more than 40lbs each for 90mm, I would think) and, during gunnery, you don't fully load the vehicle with ammunition. Just enough to complete the engagements.
WillWagner
3,036
Monrovia, Ca.
It's been a bit since I touched base here. The track is up and running. We took it out of the place it sat for years under it's own power, did a 180 and put it in the shop. Did some fixing, made a traverse mechanisim, stole a bustle rack off the stripped hull, made the hinged covers for the batteries and filter. Had to fab up a filter assembly...still lookin' for that if anyone has leads, PM me!! made a barrel, did some body work and gave it a squirt. Took it out for a putt and found it had no power. A quick check and found the filters plugged. The attached video is of the first run. Took it back to the shop, changed the filters and gave the fuel and tanks some TLC. Took it out a second time, it now has RPM but is lazy shifting and the RPM stays up when we trun but the vehicle slows. I think we have a trans issue, maybe a dirty filter, fluid is clean and at the proper level. More TS to come tomorrow!
[media]http://www.youtube.com/watch?v=YMidg_WYyMU[/media]
3cavtanker
Colorado Springs, CO
I was a tank crewman on M1A2's and most of the time we took the rounds directly from the shipping pallets into the tanks at an ammo dock. However, when we went to Bosnia and Iraq and received "used" rounds (ones that had been uploaded and then downloaded again, we laid out all the ammo so that we could inspect it all before we put it in the ammo racks. you don't want to roll into a sticky situation with ammo that has gotten wet or has a damaged case.
jimk
47
Syracuse, New York
The blue tipped rounds are target practice 90mm APBC-T (armor piercing ballistic cap tracer). Projectile is solid shot with a windscreen (not a shell). They weigh about 23lbs and have a muzzle velocity of about 2,800 ft/s (1,900 mph). I think they are identical to service rounds and may have been used as service rounds. The cartridge cases look like brass in the picture (turret) but were probably lacquered steel. The tank is a M48 Patton.
p.s. They were used very little in combat (VN) as the north had little armor. HE (High Explosive) was the preferred round.
p.p.s. Ridgerunner, thanks for posting these pictures.
Augdog1964
15
Richmond, IN
Great pics!
Nice pics, I always like the look of the Sheridan!
I had an opportunity to see one run at Knob Creek a few years back... was an impressive machine. Anyone ever see one live fire? What was the condition of the target, and what were the stats on penetration for that gun?
Thanks!
