cucv1833
- 4
- 18
- Lake Charles, LA
hello all. im still having a fuel problem and dont know what the next step should be. i read the TM 20/34 and searched. i have a M1008 still having a air in fuel problem. when i use the bleed vavle i have a good stream of fuel with no air but the bubbles end up comeing back at some point My question is
is that a problem to be address from the fuel filter back to the tank or could it be a problem with the injection system
so for changed all rubber fuel hose
fuel supply pump
fuel shut off solenoid
fuel filter base and 2 filters
clean tank and sending unit
i have checked for leaks hot, cold , and under 4psi pressure and cant find anything
i have spent about $500 trying to solve this problem $300 of it was a diesel shop that robbed me
I changed the "fuel shut off solenoid" because i went days without any air in the fuel that i could see
and she kept stalling after a few miles after it stalled i would check the bleed vavle and most of the time there
would be NO air bubbles.
should i Try a SPIN ON FILTER first or go ahead and change the I.P. ??
Thanks and sorry i know theres alot of spin on filter post but
looking for more info
