And it's wednesday!Yes, but only when you have a 24v alt hooked to two batterys and a second 12v alt hooked to one(of those two) battery.
I carry a load of dirt in the bed with a ground rod.Maybe I'm the smart one here this time... ALL grounds are eventually going to the chassis, unless you opt to string a ground wire from your truck to a metal pole pounded into the ground?
'Tanner'
Everything grounds to the seat bolt. The bed winch is grounded there now too. The seat bolt is the life of the truck. I want my azz GROUNDED.Is that grounded to you seat bolt too DUG.
Yupif you remove the seat bolt the truck fall apart? is this bolt the main-hold-everything-together-bolt?
