mistaken1
- 6
- 0
- Kansas City, KS
I think thats the one I changed ... actually pretty sure ... I changed it to the 24v ... but I ll go to NAPA and get the 12v ... Anything else that I should look for while I am there or get from NAPA that needs to deff be replaced do to putting the wrong part in ?
Thanks,
Putting in a new relay with a 12V coil should allow the glow plug controller card to actuate the relay sending voltage from the top/feed side to the bottom/load side of the power terminals.
You should be able to measure 10V to 15V from the bottom/load side power terminal to ground when you first turn the key on with a cold engine.
