What years 6.5 turbo
54
XENIA OHIO
What years 6.5 turbos can be used ? I have a 85 M1028 that I would like to put a turbo in . Did the 6.2 diesel ever have a turbo from factory. I dont know much about the diesel motors history. Looking to replace the motor with a 6.2 or 6.5 turbo
sandpirates
Akron, OHIO
as far as I know the 6.5 parts will bolt to the 6.2
There are aftermarket turbos for the 6.2 (Banks)
also look for the exhaust manifolds for a HMMWV with turbo. they have better flow.
Good luck
67_C-30
Sweet Home Alabama!
93 - 99 6.5TD's (up 2002 in 3500HD) will all work on 6.2's. The 6.2's never came from the factory with turbos, but the Banks kit was dealed installed from '89 - '92. The '93 - '94 GM-3 turbo will work as is because it has a spring actuated wastegate controller set at around 6psi. The later ones has a vacuum actuated controller and needs to be replaced with a spring loaded controller (available from Kennedy Diesel, SS Diesel Supply and others for around $100) Those controllers will require a boost gauge because you have to set boost level, because they are adjustable. The later turbos like the GM-8 flow a little better and make a little more power. If you keep the boost at 10 psi or less, water temp below 230, and the EGT's below 1100 degrees, they'll live long heathy lives.
54
XENIA OHIO
Thank's 67__C-30 another question. If I would want to take a 6.5 turbo off a engine would it fita? It seems to me that the crossover in the back of the motor would interfer with the cab. I am guessing that is the cross over .Or would it be better to find a banks turbo?
67_C-30
Sweet Home Alabama!
Yes they will fit. The 6.5 crossover pipe gets a close to firewall, but it stays pretty tight to the block. Here's a video of 6.5 set up in this body trucks. The 6.5 turbo sounds so sweet on these engines!
http://www.youtube.com/watch?v=nBFIqoXTsa0&NR=1
http://www.youtube.com/watch?v=Oxi--9H_qfw&feature=related
http://www.youtube.com/watch?v=hbyg3YSvBew
http://www.youtube.com/user/mikefaille#p/u/1/uweDcX0Gjic
