Front axle flange modification
gringeltaube
Staff Member
2,561
Montevideo/Uruguay
Does anyone have a good way to cut out the splines in the front axle flange without going to a machine shop?
Anyone with a small lathe can do this... material is relatively soft, doesn't take more than 10' each, preparation and cleanup included.
G.
swbradley1
Modertator
1,767
Dayton, OH
I think that is what he is talking about. On our trip to the Georgia Rally last fall in Gimp's truck my job was swapping the caps on the front from the ones machined out to the ones with splines. Reduces drag on the front drive train.
Not nearly as easy as a knockout hub but a few minutes of time and a little ratcheting and you are good to go.
sw
Recovry4x4
LLM/Member 785
1,810
GA Mountains
Short of a lathe, it would be easier to make a set. Flat plate of 3/8 or so with a hole in the middle for the axle to protrude then a piece of pipe suitable to cover the axle then cap the end.
hombre53
rantoul kansas
Yes this would be for poor mans lockouts. 99% of the time I dont need front wheels pulling. If I was planing to be off road, or expecting snow the splined flanges woulg go on, only takes about 5 min. with impact wrench. This should also give me easer steering, better milage and better tire wear. I allready have extra flanges and want to keep the original look. :)
Recovry4x4
LLM/Member 785
1,810
GA Mountains
The axle will be supported by the spindle and it's bushing. No need for further support.
swbradley1
Modertator
1,767
Dayton, OH
Now see Kenny, that's what I thought. I sure don't remember seeing anything in the desplined hubs on the truck.
sw
doghead
4 Star General /Moderator
1,179
SWB, there was no bushing in those splined hubs(I made them). I used a lathe.
As for bushings, certainly a bushing sounds like a good idea but, It is not needed. Many applications run hardened shafts directly on cast iron(or cast/ forged steel). A bit of grease and some clearance(.010" or more) is about all that is needed for this, IMO.
