promodhotrod
- 0
- 0
- BC
![M916MK17.jpg M916MK17.jpg](https://www.steelsoldiers.com/data/attachments/156/156512-21c5460153987ff745de4fd43a99c0d9.jpg)
![DSC01325.jpg DSC01325.jpg](https://www.steelsoldiers.com/data/attachments/156/156513-04196a5938f9a1c503334a82dc37736f.jpg)
![DSC01329.jpg DSC01329.jpg](https://www.steelsoldiers.com/data/attachments/156/156514-6668aad207e4eeee8473640e9a29f0b7.jpg)
So here is the M916 MK 17 hybrid I've started to build. I'm thinking of calling it the Prius for short. This is my first real input to this (or any other) website, hopefully I'm doing this pic uploading thing right. If so these are the original pics of the two donors and a chopped up pic of the final concept. So far the project is going pretty easy, the RBU frame is the same cross sect as the outer on the 916 and will slip over the existing inner with little fuss. The material handling crane runs beautifully on the hydraulic winches aux pump, and a gear change and air locker is destined for the front axle to match the rears. This truck will have fully selectable numbers of wheels drive 1-6. The winch is shown here moved behind the crane , but I'm on the fence on that. Thinking of moving it to the front for better weight distribution when there is a heavy load on the crane , or to pull myself deeper into a predicament. I had originally planned it for the back to pull my dumb but out of a hole if I got stuck, or to pull stuff up on a towed trailer as it was originally intended. Would enjoy your feedback. Ill post more pics as the build goes on, but Im slow so it will take a while to complete.
KJ
