cmroles
- 0
- 0
- Phoenix, AZ
I just wanted to post some findings from a little experiment I did the other day. As we all know the M1009 headlights are adequate, but not what you would call "bright".
I decided to test out the claims made by Sylvania that their "Silverstar" line of headlights is 35% brighter than standard halogen.
As a job I install professional video equipment in commercial venues. Because of this I have access to various test equipment for measuring brightness, color, etc.
To start with, my M1009 had relatively new (only a few months old) standard Halogen headlights ($10.99 each). I measured the standard headlights on low-beam with a LUX-meter and measured 480 lux.
I then installed the new Silverstar headlights ($19.99 each) and was able to measure 650 lux. Based on these numbers there was actually a 35% increase in measured light output. In addition, the color-temperature is higher giving a "whiter" light on top of the brightness.
Just my
, but next time you need to change your headlights the extra $10.00 each is worth it.
Just my
