rebuild kit starter
kcbbqguru
kansas city
Don't waste your time, search e-bay for a gear reduction starter, you can get a "new" one for less than $100, it is a much better unit than the stock one
Warthog
231
OKC, OK
who has a rebuild kit for the 6.2 starter? 24V thanks
You need to tell us what type of starter it is.
Old style direct drive or new style gear reduction. If you change types of starters you also need to purchase/install the correct support bracket.
There can be many issues with the starter so I recommend taking it to a starter/alternator rebuild shop. Thye have the proper tools for testing.
Warthog
231
OKC, OK
Where can I find the bracket for the gear reduction starter?
From your local GM dealer. The part number has been listed many times before. You many be able to read the number from the above picture. GM 22502557
It is not in the tech manual for the CUCV. It may be listed in the HUMVEE manuals, but I have never checked.
mr.travo
Comfort, TX
Thanks Warthog! I was looking through my manuals and didn't see it, that's why I asked. I will check it out and repost the PN on here so others can search it out.
Warthog
231
OKC, OK
I've posted it many times and in the above post. If you do find it in the HUMVEE manual, list the manual number and the figure number.
chevymike
460
San Diego, CA
As for the GR bracket, I actually called a local Chevy dealer and they had one in stock. You might try starting with your local dealer. All I did was to have them check stock on that part number. Never even gave them a discription, just the number.
