Towbar from NC to NY state
cattlerepairman
3,281
NORTH (Canada)
Hello, guys!
I need a medium towbar taken from 27813 (Black Creek, NC area; near Wilson, off the I95) to 13669 (Ogdensburg, NY) to a commercial address.
Any chance?
Recovry4x4
LLM/Member 785
1,808
GA Mountains
I had my first one shipped from Peoria IL to WPB Fl and it was $125 shipped in 2 pieces. Second time we shipped it in 2 pcs from Boca Raton FL from someone with a UPS Acct to Lavinia TNN and it was $85.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
Let me add this little tidbit. If sending it with adapters, send the lunette side with the 3/4" pin only. Put both adapters on the swing side of the bar. This will keep the lunette side from exceeding the magic 70# mark where things get exponentially more expensive.
DieselBob
13
Arnold Maryland
Just from my experience be sure to check FedEx ground. I have shipped a couple medium size and weight items and every time I compare UPS and FedEx, FedEx always is a couple dollars cheaper. 2cents
3dAngus
101
Perry, Ga.
There are several different type of "medium" towbars available on the market today. I can personally think of three right off hand. Here is the data of one of the "Deuce/CUCV" medium category towbars. (MRAP Medium is 220 pounds with feet and all pins.)
Hunter towbar shipping specs in pieces;
Pintle hitch end, 48 lbs. 54" length
Swing arm end, 36 lbs. 46"
Extension arm, 25 lbs.
Extension arm, 25 lbs. add 7" when inserted
Feet with 5 pins, 16 lbs.
Total weight, 150 lbs.
If a complete towbar, There is no way to combine these units into two shipping packages to avoid overweight fees of 70 lbs.
Three packages are required.
Pintle hitch end exceeds length requirement of 48" to avoid extra length fees via UPS if shipped from UPS store.
Packaging alone is averaging $10 for boxes each at UPS store X's two boxes.
Having it packaged by UPS store is another $10 each fee for labor.
If one has a UPS account, considerable savings can be occured, but it would still be $100 plus if towbar was complete with both extension arms, feet, and pins.
Conclusion: Package yourself for savings after finding boxes and carry to UPS direct rather than the UPS store. Your labor is free. Consider two hours for labor to package and carry. You could ship for less than $100 this way, even with insurance. My UPS shipper is 35 miles away, so check you local direct shipper address for transport to the site. Freight palletized shipping is easier and doesn't cost anymore if you are the one doing the shipping. Prices will vary from $105-165 depending on distance shipped. You still have to meet with the carrier, so there will still be labor and fuel considerations. They do NOT come in neighborhoods with large tractor trailer rigs without incurring extra fees of about $45 on each end. Add to weight if you purchase towbar axle clamps or any other commodity.
cattlerepairman
3,281
NORTH (Canada)
3dAngus, thank you for this very detailed analysis, the weights and measurements. I am sure that this will help several other people as well!
Recovry4x4
LLM/Member 785
1,808
GA Mountains
When I've shipped mine, I've never boxed it, just taped the pins so that the gorillas at UPS can't lose them. I can't remember which bar I shipped, might have been the one minus the MWO which makes it a little lighter.
cattlerepairman
3,281
NORTH (Canada)
It appears that the UPS quote, from the customer service centre, not a UPS store, is significantly higher than anything anybody here thought it would be.
So - my transportation need is still there! Anyone?
365
Anderson Creek, NC
I'm just about done in upstate NY and will be going back to NC some time next week. The offer stands if you want me to haul it back up here some time this summer. I can get it to Albany.
