HEMMIT rims dimensions
bubba_got_you
st,petersburg Florida
Ok im going to have to ask.
Ill probably get fried by the modes for this as it could be seen as a stupid question:smile:.
[FONT=&quot] HEMMIT rims dimensions. What are they? I had an idea but need to know how wide they are.
I DID SEARCH! lol
please don't hurt me DH lol :wink:
[/FONT]
SuperJoe
Mesa, AZ
10 inches wide. does any other specs come to mind? like back spacing or weight or single o two piece. i thought these were tubeless but seen the ones a the yard had tubes. this confused me
Wrench Wench
Indiana
Personally, I like to do CAD designs and I would enjoy seeing a measured drawing with a cross sectionI can easily translate into my CAD software. Ditto for the 5-Ton front drive axles, which, now that I think about it, measured drawings of the 5-Ton axles are the original reason I joined SS in the first place.
sdo
Vancouver BC
I am searching high and low to find dimensions for the HEMTT rims.
I know they are 20"X10"
But I would like to find out
-available backspacing
-weight
-outer bolt counts (10, 12, 16 I think)
If any one has pics of the different wheels or a link to a spread sheet that would be great.
Thanks
sdo
Vancouver BC
Thanks for the info.
Are the HEMTT wheels only available in one backspacing?
dose anyone know what this wheel might be off of, and and dimensions of it? (weight, backspacing, load capacity, lug circle, centre hole size)
5tondeuce
Hampton/New Brunswick/Canada
They are a factory 5 ton wheel,May be off the 900 series but not sure.
Dimensions:
20"x10"
11-1/4"" bolt circle(common on all, 5tons)
8-3/4" center hole
11-3/8" back spacing
appox 130/140#s(just a guess)
10 bolts that hold the two piece rim together, 5/8" studs
rim thickness at bolt holes is 3/8" thick so you don't need longer studs.
Rim can be mounted both ways , front facing outward or inward.Lug holes are tapered on both sides.
5tondeuce
sdo
If you go to ebay.com and type "military wheels" you will sometimes get quite a varity
of wheels. I have seen wheels on there with different back spacing but I am not sure if they are hemmt wheels.
Unforgiven
Las Vegas, NV
Dimensions:
20"x10"
8-3/4" center hole
Are the HEMTT rims also reversible?
