GP Relay Grounded?
tgtaylor64
Florence, SC
I noticed on three different M1009s that the glow plug relay is bolted directly to the firewall (metal to metal), and thus grounded. I just purchased a new GPR and noticed that they have nice rubber boots that effectively connect it to the firewall with no grounding. I can see where the rubber would provide some vibration damping when the relay is energized. I studied the TM and it does not indicate to ground the body of the relay. My question is: should it be grounded or not or does it matter?
Warthog
245
OKC, OK
The relay MUST NOT use the chassis for a ground. If it does the relay will stay energized all the time.
There are two types of relays.
One that uses the mounting bracket as the ground for the coil - DO NOT USE
The other has the coil isolated from the mounting bracket and has its own ground terminal - USE THIS TYPE
It may or may not have rubber feet for vibration control.
HAWKMAN
N.E. P.A.
I've fried a GP card or two grounding the relay.....I wouldn't do it, besides what harm could it do to keep the rubber 'shock' pads on the relay?
Warthog
245
OKC, OK
I found this part number at work for a 93-03 Ford 7.3, AP63405 will this one work also? Runs about 30.00 bucks.
Why would you want to use a ford product on a CHEVY truck.......:razz:
