jamboly
- 7
- 28
- Brenham, TX
Got my 920 a couple of weeks ago. Working through problems one by one. I am now trying to determine why batteries (new) aren't charging. I started out by looking at the voltmeter gauge (on dash). I have attached a picture of the wiring as well as a partial diagram of the wiring to the voltmeter. The first thing I noticed was that the leads that should normally be attached to one of the meter terminals was attached to the bolt that is used to hold the bracket that holds the meter in, instead of the meter lead, which had no connection. I figured this would be an easy fix by just moving the two wires to the meter lead. Before doing that, I checked to see where these wires went. I found that one of them (labeled 98B went in to the wiring harness. The other one went to one of the terminals on the engine start button. That is where I became concerned. You would think that that terminal would get 12Volts to it when the ignition is on and the button pushed. With the other end being connected to the gauge bracket (chassis ground?), you would think I would be seeing smoke when I started the truck, but I don't. It starts just fine.
I would appreciate it if one of you guys that has a M915-920 would open up your gauge panel and see how your volt meter is wired.
Note that I found a partially melted connector in the cab that goes to the ignition switch that someone had changed out, and all the wires from the new one are spliced at the wiring harness, and I don't have many wire numbers.
If I just had a wiring diagram.
Jim
Jim
