Duncan.
Now that youve done the cab swap . what is the fastest way to do it. Can you leave all the ctis stuff and batterys in place? Just trying to figure out how many man hours it would take.
thinking about getting one.
Also always looking for tires and I need axle boots for my 805 if you run into any deals
Thanks
I've been asking around for those axle boots but no luck so far. I'm planning to buy new tires this fall, after I get my road-trip done (we're going to do a 4000km trip in july). Will have to see about pricing and such then, might be able to make a deal when ordering 16+ tires
On the cab change, it's very straight forward. By far the eaiest way is to use one of those movable cranes mounted on ceiling beam, but we used a forklift and some strong langauge, and that worked too.
First off, remove the dashboard. Start by undoing the 3 electrical connectors. One big one is on the left side connecting the dashboard to all cab wiring, the other big on the front plate connecting to the chassis wiring, and next to that is a smaller one which is the + wire.
Remove the 2 flexible drive cables going to the tacho and speedo, the air line coming from the CTIS to the metre on the dash, and the oil pressure hose (comes in from the right side).
Now there is a little problematic point, which is the oil temperature meter. It's not removable from the meter because it's a sealed tube. Your options are to disassemble the main combined instrument, or to remove the sensor plug from the oil tank and take the whole tube off along with the dashboard. Last option could be to cut it (I did that as mine was broken anyway) but I have yet to find someone who still sells new ones. Taking apart the combined instrument panel is a horrible job, so if I had to do a swap again, I would remove the sensor from the tank and plug it quickly to prevent the oil from gushing out.
Remove the gear lever, theres a bolt holding it down and an electrical connector for the splitter switch.
Anyway, that should be all connections to the dashboard dealt with. Now it's only connected to the cabin with 2 bolts. One is next to the gear lever hole, the other one is at the driver's door side and probably hidden behind the door seal rubber. Second picture shows the bolt, with door rubber removed.
You have to disconnect the oil cooler. There are a few options, either remove the 2 hoses from the cooler to the engine, or remove the grill from the cab (drive out the pins to the 2 hinges on the top), or remove the cooler from the grill without disconnecting the hoses. I did the latter, to keep the oil system closed.
While you're at this side, remove the negative power cable going to the main power relay in the air intake compartment. Either remove from frame or from the relay, it doesnt really matter.
That is the hardest part completed
Now you need to move the steering column. Very straight forward, theres a big nut under the rubber boot covering the hole in the floor. Pay attention to the horn wire, it runs through the column. You can remove the central plastic part on the steering wheel, disconnect the horn wire, and then take the steering column off completely with the wheel. Watch out not to drop the horn wire because it will fall in the steering gear oil tank and you will spend an hour cursing and fishing it out with a bent piece of welding wire, trust me
Now, remove the lever for the winch break, it's held on with a split pin only. It sticks out jsut a little too far so the cab floor wont clear it when lifting. The same applies to the clutch lever, I removed the bolt connecting it to the cylinder so it goes all the way up. Not 100% on what we did with the brake lever, you'd have to see that for yourself.
On the back of the cab, the breather hoses are held with some metal clips, and the air filtration unit is connected with a rubber boot to the pipe coming from the cab. Disconnect these, obviously.
Now the cab should be completely clear. It's held to the frame rails with 6 bolts, 3 on each side. You can access them from inside the cab. 2 are under the bench behind the heater, 2 are
First, there are 6 bolts used to secure the cab to the frame rails, 3 on each side front, middle, and rear (under the bench). Then there are near the rear of the engine, and 2 near the front. A few have a welded nut in the frame rails, but not all. You need 2 people here, one to lock the nut and the other to undo the bolt, because you cant reach both at the same time. Only have a pic of one of these bolts, but they all look the same.
There is one last small bolt connecting the front panel (with the pedals, power steering and clutch fluid tanks, etc) to the cab. I think it's the one on pictured here, just above the hand throttle axle, but again, not 100%. It shouldnt be too hard to find though.
You could choose to remove the fenders and the rear door steps, it makes the cab easier to set down after removing, because it will stand flat on the ground. You can remove with fenders attached though.
Now, if Im not forgetting anything, the cab should be free. As said before, the easiest way to lift is a crane. We managed with a forklift because I removed the front windows. You have to lift pretty high because the whole cab has to clear the engine. Lift straight up untill completely clear.
For supporting the cab, the 2 small side windows are the perfect center for weight distribution. I put a beam through there, as pictured. If you want to leave the windows in and use a hoist, use a diagonal beam from drivers too to right side rear door, this is how the factory does it.
It's a very tight fit between the exhaust headers and the cab, but it is most definately possible.
Installing cab is in reverse order, but you curse at different points
All in all it's quite a long write-up, but most of it is very straight forward to do. We removed the cab in half a day with 2 people, finding all this out on the go.
