Smokinyoda
- 8
- 18
- Franklin, NC
Finally got around to putting winch on today, and I have a couple questions.
The tie down/handle does not fit anymore. The holes on the frame are blocked by the extensions. Is this normal? Should I drill through the extensions or just leave them off? All other holes line up so i'm sure I have it on right (shown in last picture).
Also the mount for the front shackles, what do you use as a spacer for the rear 2 bolts? There is a gap between it and the extension. I was going to use washers but didn't have any big enough, and curious what others used.
