This is my last and latest safety bump for 2014. I am not a mechanic so do my best to follow instructions in the manuals for both my work toys and personal toys. This makes my mechanical adventures an opportunity for an education that we can all benefit from, if I continue to live through them.
While inspecting belts I found the air compressor unit on an S185 skidsteer was a little sloppy, both at the belt and the mount. Instead of pulling the book and checking spec on the problem/solution, I grab a wee 3/8 ratchet and a wrench and go to work. It's just two bolts, how hard could it be.
The bracket and adjustment point is like most other Chev alternator or pump mounts with a main bolt on the bottom and an adjusting bolt on the top. While laying down with my face directed at the work area, I put a couple of pounds of pressure on the ratchet and suddenly hear the sound of high pressure air releasing. It was a refreshing scent of sweetness and the quick realization that this can't be good.
View attachment 534798View attachment 534799
The housing cracked at the mount bolt and freon was my immediate new buddy. I'm not sure if the head-rush was adrenaline or freon but our 'emergency preparedness' procedure kicked in. I vacated to a fresh air source, found the msds for freon which was pulled prior to beginning the job and assessed the health of the patient. I called the bobcat dealership to confirm which freon I may have sucked on, was fortunate that it didn't penetrate my tank like shell and my pink lungs are fine. Another case of too fast strong too slow smart.
All the preparation of grabbing a fire extinguisher when we're working with flammables, knowing where a first aid kit is, knowing the hazards of the toxic chemicals we're exposed to and the simplest things like knowing the spec of a bolt before you torque it will be part of my continued New Years Resolution for 2015.
Check your specs before you check your nuts, Have the Happiest, Safest New Year and remember,
Keep your rubber on the bottom.
View attachment 534796View attachment 534797
