davidkroberts
- 23
- 38
- west tennessee
i like them allot, mike be expecting an order soon....![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
I like the look !!! Not being nosy but what is a rough general total cost of the tire and rim set up ? That will be my next project ..
When I put the A3 wheels on the front of my crane truck, they had some big clunky valve stems in them. I went to replace them with commercial stems but they were not the right size for the wheel hole. I ended up going to a tire shop that does a lot of ag stuff and they had a stem that was darn near dead on but had a large stem. I got an adapter cap that went to a typical size stem and it made the length spot on and they fit the wheel hole(s) perfectly.my hemtt stems seem to be working out just fine, so are mikes.
I've heard of trouble when people try to use commercial stems in the large hemmtt wheel hole.
I finally got time to make some plates. Some guys were asking about how they bolt up differently. You can remove the outer studs, and press them into the new plate. Assemble the wheel with the plate underneath, and bolt together as normal.
This allows you to mount the wheel on the truck, and not have it sit inboard towards the springs.
The plates work both ways so the choice is yours.
