friggin batteries?
Midnight Rider
Sesser, IL
Nothing says the batteries have to be where they are. People have been relocating batteries for a long time. So you could move the battery to wherever you want, but you would want to use the proper cables.
I don't think, but I'm not sure, that you could use the rear Buss bar to feed the battery back up. To be on the safe side I would just make a new run with the proper gauge cable back to the front and be done with it.
Putting in a turbo or something?
southdave
ripley, oh/TDY Lordstown,Oh
same loation on rear bus bar used sone 4ga wire to the chassis electric.. turn over twice it worked.. plans are to get or build a battery box for some optimias for thier size. mount them on fender well... I have figure out how to mount a bronco spare tire mount on the rear first
asgtoolman
Florence SC
Optimas sure are sweet!! Put a pair in my deuce 3 weeks ago that I purchased from SAM's Club for $139 ea+- sure is easy to slide the tray in and out now; only a fraction of the weight and size
erniemigi
Amelia, ohio
Can you post some pics of what you did, that sounds like a good idea
southdave
Let me finish it up, I just removed the battery with the cables that go to bus bar in the engine compartment . I am in the middle of turbo install and then I will install somthing permanent..
