Thanks for that. I had not seen that. It may be correct, but it does not look right to me. It looks like the shroud is plastic and the ones I have seen are metal. Perhaps, Andy will come on to tell me that this is the later issue fan. If it is correct, I will be buying four.
Bruce, your right the OEM supplied ones had a metal cage. However as manufactures change production over the years I wouldn't be surprised if these were in fact the same NSN with different part numbers but suitable sups for each other.Thanks for that. I had not seen that. It may be correct, but it does not look right to me. It looks like the shroud is plastic and the ones I have seen are metal. Perhaps, Andy will come on to tell me that this is the later issue fan. If it is correct, I will be buying four.
I have 4 of them that have the metal cage, if you want. Same price.Thanks for that. I had not seen that. It may be correct, but it does not look right to me. It looks like the shroud is plastic and the ones I have seen are metal. Perhaps, Andy will come on to tell me that this is the later issue fan. If it is correct, I will be buying four.
Amongst other things...The fuel solenoid is 24V.
I'll get it out this weekend.I need a complete dash harness, more complete the better.
Don't worry. I've got this.I'll get it out this weekend.
I ordered the NOS harness from Eastern Surplus and surprise, it’s not the right one.Don't worry. I've got this.
