NRGarrott
- 0
- 0
- Annapolis, MD
Is the exhaust smoking at all when cranking? I believe a lack of smoke could indicate a lack of fuel being delivered.
Also use a jumper wire with 12v to where the pink wire connects on the pump. This is your fuel shutoff solenoid and if it is stuck you won't being going anywhere, you should hear a click when power is applied and removed. If you do pull the top off the pump as jdemaris advised you can check this visually.
I recently purchased a m1008, after much troubleshooting i realized i had a bad pump and mailed it to Arizona for a rebuild. I found the guy off ebay. The truck runs great now and the price was competitive at $265 plus shipping for my pump rebuilt. The company name on eBay is az-diesel-injection-services.
They did take a little longer than expected and communication responses took up to 3 days but the rebuild seems like good quality.
