- 1,054
- 55
- 48
- Tualatin, Oregon
NAPA has the replacement ether canisters. If you buy one would you please post up the NAPA part number?i have pictures of ice in florida. so it may but useful. but i havent figured out how to fill it back up.
When I have trouble cold starting an engine, I almost ~never use ether.
If I have electrical power close, I use an electric heat gun pointed into the intake. This works well on gas engines too. Got a Honda Trail 90 going yesterday that hadn't run in 30 years. Wouldn't start until I put some heat into the carb.
On diesel engines I usually have an assistant with a propane torch pointed towards the air intake. If you burn the air filter it's your own fault
A rag soaked with diesel and set on fire also works held over the intake but I don't like that one much. Use at your own risk. If you do set something afire, please take pictures.
. If you start running then it's ether
