Screamin' Metal
- 2
- 0
- SW Oklahoma
No....14 PSI won't be too much.....but I wouldn't go much higher without regulation.....
How did u cut the fuel line under the truck, did you drain the tank?, how long did it take you to do this.You want an Airtex E3158. When looking for an electric pump on my M1009, I sourced one that was for an '88 P30 Van with a 6.2L engine. I installed it this past weekend and it solved many problems I was having with my mechanical pump. I ran a new 3/8 rubber line to my fuel filter inlet, bypassing the mechanical pump and line under the intake completely.
Actually there is a spot up under the passenger side floor board. That's the spot he's talking about.How did u cut the fuel line under the truck, did you drain the tank?, how long did it take you to do this.
As my grandpappy used to say, do it right or don't do it at all. I would strongly recommend removing the old mech pump and pushrod, and installing a block-off plate. The reason most people go to electric vs mechanical is to save a HP or 2 by removing the mech pump from the engine, but I've also heard tale of an old pump developing a leak and losing the engine's oil. I'm pretty sure if the old mech pump no longer has diesel fuel flowing through it to cool and lubricate it, there would be a way for problems to develop with it pumping dry.I hate to bring back an old thread but if I do install an electric fuel pump will I need to take the mechanical pump out and put a block off plate were it was.
The Stanadyne injection pump does not need any other fuel pump and on some applications, there is none used.I bought an electric fuel pump it delivers 8psi to the IP,
I'd just do a Websearch and buy from whoever has the best deal.Okay JD so where do we get this walbro FRB-5 pump?
Times two now as I just picked up a M1031. THANK YOU JohnWe get it, advertisements are annoying!
