jamesonsdad
- 0
- 0
- queensbury,ny
first of all thank you WESTECH AND WARTHOG for advice on a earlier post....now for the ugly;today myself and a buddy changed the fuel pump in my m1009 old one came out easy accept for the lower cross member in the way and the back bolt almost (i said almost) impossible to get at and then the rod drops,well low and behold the 6.2 doesn't have the bolt in the front of the block to hold the rod like the GM gassers do.So after finally pushing it back and using a grease gun we got it to stay back long enough to slide the new pump in.well after two hours of fuel pump **** she's up and running again i now know why some people use electric fuel pumps as who ever dumb@#$ GM engineer didn't put any thought into changing the fuel pump in the field.Next time i'll just pull the motor it'll be quiker
