grw800
- 3
- 0
- Terlingua, TX
I just replaced a broken starter bolt on a CUCV and thought it would be helpful to post the info here. The bolts are GM P/N 15544950 (this part number supplies one bolt). The size is M10X1.5 X approx. 111mm length. The strength grade is 9.8.
I had the threaded portion of one bolt broken off in the engine block. I used a transfer punch to mark the center, and then used a left-handed drill bit to remove the broken part. Replace both bolts with new ones--it's cheap insurance. And it's imperative to have the support bracket in place on the front of this heavy starter.
