5 reverse gears one forward
jtrojan715
Paradise ca
well i found out first hand today that a deuce motor Will run backwards!!!!aua
up in the hills with some friends (showing off) went up a steep bank killed it rolled backwards cought the clutch and it fired right up :shock: blew the intake cover that sticks out on the finder right off! shut it down waited a sec fired it up ran just fine cant belive how easy thies things bump start read that the do but man.
wreckerman893
Possum Connoisseur
15,647
2,140
I did the same thing at the gate at Redstone in the M275. I had to shut it off while they did the entry inspection. When I hit the switch nothing.....it was on an incline so I let her roll back and I though it was in reverse...nope....had it in second...she cranked up and I actually drove it through the gate running backwards....made a quick U-turn...shut it off and then rolled it off in second...cranked right up and ran fine...still running fine....the guards could not believe it.
I also sucked a grease rag through the engine.....spit black pieces of charred cloth right out the exhaust.
Multi-fuels are tougher than woodpecker lips.
sigo
Lieutenant Colonel
444
Leavenworth, KS
... I also sucked a grease rag through the engine.....spit black pieces of charred cloth right out the exhaust.
:shock: Sweet. I know multi fuels will run on most anything, but greasy rags? That's going too far. Skip the WVO, just feed it fries, or chicken wings, she'll burn it and shoot the bones out the exhaust.
hndrsonj
Senior Chief/Moderator
371
Cheyenne, WY
Yep, another good call. Right up there with lacquer thinner.aua
Ferroequinologist
Resident railroad expert
4,812
748
Liberty Hill, SC
If you could get them to though....
Would be good for rail service. They have old single pistion inspection cars, you would kill the ignition, flip a lever to reverse the timing, then on the very last compression stroke of the engine, turn the ignition back on and it would run in reverse, then you could go back.
Could get a deucomotive! all gears forward and back. Could you tie in an electric pump, like what lots of guys did for prelubers?
224
Independence, OH
Been there, done that... Maybe we need a T-shirt.
Did that last year. Brother pulled the deuce into a tree and did a stall and an instant restart on the rebound, of course in the same gear. While he was looking to find what happened to reverse, I was looking at all the smoke coming from the hood. ( ??? )
Pulled the air intake and got a face full of exhaust. ( ??? ) Reached up and felt the J-pipe sucking air. ( Aha ! ) Killed the engine and restarted. All was happy.
Posted it and got a long letter on why the engine could not run backwards. Followed by a whole lot of people supporting me on how it could and did. They gave many of their own examples of deuces and other diesel trucks running backwards.
All I can say is if you own a deuce, there is a chance that some day you too may own a deuce that blows bubbles in the oil sump.
A
A/C Cages
Guest
Well running backwards is a great excuse the next time I forget which vehicle im driving and throw it into reverse instead of foward.
Why cant they make all transmission patterns the same? lol
Recovry4x4
LLM/Member 785
1,827
GA Mountains
I was about to indicate that soon a whole bunch of shadetree mechanics were going to appear and explain with great specificity why the multifuel CAN'T run backwards. You beat me to it. I'm also on the shortlist of folks who have run their multifuel backwards. If any naysayers want to stop by with their title, I'll light mine up backwards so you can see!
bill2444
cheboygan/mi
My old well rig had a 6v-72 Detroit, that didn't have enough low gears. Several times i have stalled it loose sand and on restart it would run backwards. Ran good but with a slightly different roar to the motor. Never hurt it. To this day it's still drilling in Africa somewhere. One of the old guys told me that sometimes when it was stalled and on a compression stroke at the right point in travel in the right cylinder when you pushed in the clutch to disengage from the load of the drive-train it would start the motor back up in reverse rotation.
224
Independence, OH
Amen to that! Let me know if it happens and I'll arange for some popcorn!
gomerkfx700
grundy/va
the key with our old mack trucks at work is gettin it choaked down were its loading up the turbo with fuel then when it kicks back its got a supply of fuel to burn built up in the exhaust and turbo. ive done it countless times. the old maxidyne 237 with the fuel cranked up will do it in a heart beat specially if you stick a new guy in it and he cant figure out the two pole tranny and cant get it into low range lol its always a kick to watch the new guy who thinks he can drive anything climb in like he is goin to tear up the world and then holler on the radio and ask why he has 5 reverse gears lol. and whats this other stick do ahh good times
ODdave
41
lansing michigan
Have to figure out some way to change the IP timming so you could get an equal amount of power in the ccw rotation.
Boy wouldnt this piss off a sprauge t-case !!
