- 3,923
- 75
- 48
- Comfort, Texas
Time to address the cargo seats on my Deuce bobb project. The wood was in very poor condition but the fact that I could cut off one 36 section made my repair options. I started by removing all the slats. This in itself was no small job since the nuts were near impossible to get off with further damaging the wood. Solution was to drill a pilot hole in the bolt heads that were stuck and the insert an Easy Out to hold the bolt while I removed the nut. A dose of PB was helpful. Once removed, it was a trip through the wide belt sander and then I repaired the bad sections by installing a half lathe joint, followed by drilling the bolt recesses as required. I will post more pictures once I apply sanding sealer and paint.
My original plan was to go with fiberglass slats or new wood once I got pricing, creativity took over.
