GFB
- 1
- 18
- Northwest IN
Card is toast, but the push button system is up and running. Getting 24v to plugs. Do I need to buy a new resistor bank or are the 60G's ok with that much voltage?
I'm not sure what you're saying. I'm measuring voltage at the glow plugs. The only time they will receive voltage is when the relay is energized. If I'm receiving 24 volts at the plug, then I'm getting no or very little drop across the resistor, right?With a functioning resistor and stock glow plug relay wiring you will measure 24V at the relay until it is energized. The resistor will not develop a voltage drop without current flow. You have to measure the voltage at the relay when it is energized to see the voltage impressed on your glow plugs.
Another option is to place your meter leads on either side of the resistor when current is flowing to see the voltage drop across the resistor.
Correct. No voltage drop at the glow plugs means there is no current flow.I'm not sure what you're saying. I'm measuring voltage at the glow plugs. The only time they will receive voltage is when the relay is energized. If I'm receiving 24 volts at the plug, then I'm getting no or very little drop across the resistor, right?
Are the 60G's ok with that much voltage?
