MakersTeleMark
- 0
- 16
- Colo.
I'm installing this to charge my house battery in the camper while I'm driving, and for a couple of other reasons:
Product Documents for Add a Battery - PN 7650 - Blue Sea Systems
I'd like to mount the switch and box in the cab behind the bench seat. For those of you who have routed pretty large battery cables, what is the simplest way to route it (102
? I'd also need to have a way out for the incoming + and - from the house battery, but can likely use the same entrance.
I'll be pulling off the front battery and will likely install a stud or bus under the hood to keep the battery connections clean.
Thanks.
Also, for pulling 12v when the key is in the start position I planned on run a wire from the starter relay where the purple/white is connected. See any issues with that?
![Cool 8) 8)](https://www.steelsoldiers.com/images/smilies/icon_cool.gif)
Thanks.
