3dubs
- 3
- 0
- Houston, TX
Last time I learned to use a butane torch to heat it up until the teflon or whatever squirts out. But now I have to replace the U joint by the trans. I got the old one out fine but now I can't get the new one in. I have part number 534G. But when I get it on the drive shaft it is real tight and does not move freely. When I try to put it on the slip yoke I can't get both caps on. I thought a bearing came loose and was wedged in so I bought another U joint and made sure grease was holding them. But I still can't get the last clip on the U joint. I just bent the handle on my clamp but it is not going in enough to put the clip on. I only threw one tool because my little girl was watching. Has any body else had this problem? Is there another part? I checked the TM and got part #7806140 then put it in LRC and got the 534G part number. It is very close but just not close enough.
HELP!!!!! Before I break something.
