I've been challenged by a hard start issue over the winter and attributed it to a fuel leak at the injector pump head and old filters.
Now it's warm and ice changed the filters and fixed the leak but I'm still having issues. It will start most of the time above 50 degrees without a problem but then idle at 450-500 till I tap the gas and then it idles fine. This noting it was 40 something and I had to give it a little gas to start.
I noticed some small air bubbles in the return line from the injectors. Could this be the source of my problems?
