- 2,052
- 56
- 48
- Milford / Michigan
Well I got my WMO system in production last night. still need to make brackets to mount the filters on the drum, but thats just a cosmetic thing more than anything. i have 4 filtering stages, where first stage is a 60 mesh pickup screen then a (using Zinga filters) SE-25, then SE-10, then an SE-05. thats filtering 25 micron, 10 micron then 5 micron. the system is simple. pressureize the drum with 7psi of air and a pickup line goes almost to the bottom of the drum (so i dont pick up the crud). so the oil goes through the first 60 mesh screen, then 25 micron filter, 10 micron, and then 5. i would like to get a AC condenser from a car and use that as a heat exchanger with a small propane heater would help the flow and possibly have a higher quality filtration although i dont know if warmer oil will filter better our not. i say filter better as in take more particles out of the oil. i only push it 7psi to go easy on the filters. it takes a little while to filter the oil, but so far i made 25 gallons last night, not bad at all. i just pressureize the tank and walk away and just keep an eye on the 16 gallon drum i fill into so it dosent over fill. im guessing i might be filtering 1/3 a gallon per minute. Thats fine with me, I am in no hurry as long as it gets filtered good. The filters are rated at 30gpm i think. I would like to add another zinga filter that filters down to 3 micron, but i dont know if napa carrys that filter for this style base. I have more research to do on on that. Anyway let me know what you think! ![Razz :razz: :razz:](https://www.steelsoldiers.com/images/smilies/icon_razz.gif)
