817 going to the scrap yard
73m819
319
gainesville, ga.
I could use a front spring perch, front gear cover off the 250, and the front motor mount rubber insert, upper and lower rad. mounts
KsM715
142
St George Ks
odd ball has been around for a long time under a different name and had WAY more than 100 posts.
Thats a downfall of deciding to change your user name without going through the admin and seeing if they will change it for you.
Edit: unless he did and they changed it and reset his post count, well then that would sucks.
Jimma
Hartwell, GA
Oddball has been on here a while. He was televisionman until my brother and I started calling him oddball at the Georgia SS rally. He is not trying to reach a magical number, he is a very active participant on this site and in the MV collecting world.
73m819
319
gainesville, ga.
Yep when I changed from M52 to 73m819, I had to start over but it didn't matter
pat038536
Sacramento CA
If I had any extra cash on hand.. I would take all the tail/turn light assemblies, wiper motors, fuel tanks, air tanks, entire brake system front to rear, cab body w/doors and probably other stuff I can't think of at the moment.
Too bad the Taxman came knocking first. How, I utterly dispise the taxman.
