395's mounted, how to fix rubbing?
gimpyrobb
dumpsterlandingfromorbit!
27,786
769
Cincy Ohio
His idea doesn't sound too bad. The wheel centers have the bevel for the budd nut and should keep the wheel surfaces tight against the wheel mount surface. It is plausible.
5,048
Yeah I had talked to the guy making sure he could bevel the lug holes as well.
I'd like to try it, but in a way I kinda wanna keep my dropside 10 wheeled. But then again, I've got a spare set of wheels...
keithc
Lincolnton, Ga
I thought about the wheel centers as well, but they are only 7/16 thick. I put longer studs on my hub and added washers and even put nuts on first, then the rim, then the regular lug nut to get an idea of how much clearance I would need. I need at least 1 1/4 " to avoid rub. To add insult to injury, some smart a** spot welded my steering adjustment bolts.
gimpyrobb
27,786
769
Cincy Ohio
The washers are a bad idea(to run on the street) because the wheel needs to be clamped against the hub so it doesn't flex and crack the wheel studs. That is what happened in my case. Using the centers from a stock wheel would be a good choice (imho) but it sounds like they will not give the required clearance. Sucks to hear it.
197thhhc
15
Williamsburg, OHIO
We got our first wheel back from the machine shop with the center flipped . Running it this way offsets the wheel 7 inches out from the original wheel. We should have the full set soon and will mount them on our next bobbed unit with 395s. You could also flip the wheel back around, split ring to the inside and get a couple more inches of offset. When we get the rest and blast and paint them I will post more pics.
keithc
Lincolnton, Ga
Yeah, I didnt drive with the washers. I just had the front axle jacked up for easy steering. I was in the process of looking for m135 rims tonight. Do they have the same "look" as the deuce rims? I just hate to dismount/remount the 395's.
Harleighguy
Placerville, California
197thhhc, Ok so I am thinking the centers were cut out and rewelded in?? Does it alter the split ring mounting at all?? You DON'T even want to see one of those POP off... I have seen the result of someone standing on top of the rim when it let go... End result is 2 broken shoulders, broken arms, oh yeah... he died too when it broke his neck and removed his jaw~ What a mess....
197thhhc
15
Williamsburg, OHIO
Harleighguy I appreciate your concern. Its good to know other people are as concerned about safety as I am.The centers were just machined out. The wheelhoop wasnt touched and the weld is not on the splitring lock. I have also seen someone killed by a splitring improperly attached when I was in the Army. This is why they are done by a machine shop with a certified welder instead of in my garage. Safety is the most important thing to us. Thats why when we bob a deuce we dont just remove and axle and cut the frame. We go thruogh the entire brake system and replace the wheel cylinders, hoses, master cyl and at least rebuild the airpack. I will put the split ring on and take some closer pics. Its a nice set up. [thumbzup]
