CROM
- 0
- 0
- Des Moines, IA
OK, a simple fuel filter change has turned into a nightmare. Here's the deal: I drained the existing filter by loosening both vents (top and bottom) pulled the old filter off, pre-filled the new one and installed. Tightened the lower vent, left the top vent open and fuel cap open. I ran a small tube from the vent port on the top left side of the filter housing up to a bottle that I can see from the drivers seat and disconnected the pink solenoid wire. (both negs on both bats disconnected during removal/install and connected now)
The problems began when I couldn't get the fuel system to bleed. No matter how long I cranked, I could not get fuel to flow out of the tube. I have half a tank of gas and am on a slight incline in my driveway. I cranked until my batterys just about died and I had to charge them. Then my 'diesel mechanic' neighbor came over and suggested I had air lock. He suggested spraying WD-40 into the intake and turning the engine over. After a few goes, the starter started whining and eventually quit trying at all. I'm currently letting things cool down, including my head, and am in need of your expertise! Please help!
