KsM715
- 142
- 63
- St George Ks
Nice job Id like to do that to my truck this upcoming spring or summer. Can you get some pics of how you did the hinge?
Sounds like a 5-ton wrecker t-case PTO. They don't have an engagement lever and run all the time the truck is in gear.After looking at your install I realized my (possible 5 ton PTO) does not have a control on it so it would run all the time the transfer case is engaged.....I don't think that woul have worked anyway....boooo.
Do you mean PTO instead of "pump"? If so, the PTO drives the power divider which in turn powers the hyd for the crane or the rear winch.What did they use this pump for?
Thanks
Charlie
Every M62 I've seen, the lever goes to the power divider. The PTO turns all the time and the power divider shifts in and out.My M62 wrecker has a part time T-case pto. It is only on when I pull the lever.
Can we see some picts of your set up? Looks good in your avatar! What cylinders did you use? frame work? Hinges? Pump and wiring?I went with electric on mine, 12V runnin off one battery. I have no uneven chargeing issues. Glad to see other have had the same isea. They work great as dumps
