Road trip to Alaska
So what do you think of Ferro's Trip?
  • I'll convoy with you!
    Votes: 34 15.6%
  • Stop by and have a beer when you pass through
    Votes: 64 29.4%
  • Good Luck
    Votes: 91 41.7%
  • Don't do it
    Votes: 0 0.0%
  • Ferro's lost his #@%^* mind
    Votes: 29 13.3%
neilhendrix
Reidsville N.C.
dionmtn:
This is Ferros trip but I invited myself as his co pilot. You would be more than welcome to leave your stuff at my house. I hope this trip comes together as planned. It would be well worth the sore arss and expense for me at least. I`m hoping he waits til 2012 for the funds to build up. The cost of fuel keeps going up so the cash has to be there.
:driver::driver::driver:
Ferroequinologist
Resident railroad expert
742
Liberty Hill, SC
Sigh,
Yes, as much as I had hoped to go this year, it is just not in the cards right now. With my new business startup, lack of time off saved up at work, and lack of $$$, I will have to push it to next year as Neil suggested.
It is still on though! Just more time to prepare. Looks like the m109 will be getting a winch too, although I may hold off on installing it until AFTER the trip- several hundred pounds of weight saved. I'm hoping we won't need a winch for the trip!
dodgedougak
Joseph, OR
Making plans for the MVPA ALCAN trip in 2012. The M37 should be back together and road tested. Now I have to find a good M101A1 trailer to haul the "possibles" behind. I think I have most of the parts to finish the rebuild, other than a set of 11.00 X 16 Michelins.
bigmech
Potterville Mi 48813
I have been there ( Alaska 2 times) I coverd 2,200 miles after we flew there each time. You would need to run in groups there while driving military vehicles so you would have folks around you that know how to work on them. Not many repair shops that are cheap.
davidkroberts
23
west tennessee
thats awesome ferro, were you planning on jumping in with the ALCAN guys for a portion of the trip. I am going on it maybe we can convoy up to Dawson Creek together since youll be passing close to west tennessee anyway.
blybrook
Fairbanks, AK
Just so everyone knows, the current cost of on road diesel in Fairbanks, AK is $4.43 per gallon at one of the local stations, have seen it as low as $4.17. Things are slowly rising.
Good luck to all that drive up here, hope to meet a few of you when you arrive.
Shoprat 19th Engr
prince george , va
Daul voltage Alt.
I would not worry abuot a daul voltage alt. The only thing you need to do is come off the + side of the battery that is grounded to the frame . Put a 60 amp breaker or fuse and run a#0 wire to a new fuse block (you can get this at NAPA or a speed shop and run all of your 12v ass. off the new fuse block.
tm america
24
merrillville in
I would not worry abuot a daul voltage alt. The only thing you need to do is come off the + side of the battery that is grounded to the frame . Put a 60 amp breaker or fuse and run a#0 wire to a new fuse block (you can get this at NAPA or a speed shop and run all of your 12v ass. off the new fuse.
Hope you got a hook up on cheap batteries and alternative customer you will need them if you run off just the first battery to get 12volts
