eagle4g63
- 34
- 48
- North/west Indiana
Ok, so I went to Napa and bought the #3512 secondary filters EVERYONE seems to be using on their deuce, I asked the guy what the micron size was he replied 10(ten), I had him look up the 3511 primary and he came up with 10(ten). I am converting the primary to a spin on with the filter base #4770(which I have one for the oil filtering rig cause it is NON-bypass) and went with the filter #3522 it is a 10 micron with water separation drain.
NOW, my question I have (which I can't seem to find a straight answer) is W-T-H is the ACTUAL micron size from the MILITARY!!! Some say the primary is larger than 10 and others say not, some say the secondary is smaller than 10 and other say not.
I am soooo confused.
Second question, would it be wrong to go to a finer micron on the secondaries when I convert them to spin on???( too much resistance for the injector pump to keep feed)
Third, why are we bothering to pre-filter the used motor oil down past the micron of the filters on the truck(or better yet why at all) if we can just reach under the truck and change the primary with the same flick of the wrist that we take to change the one on the filtering rig(and the same cost!!!!) just save lots of time and the cost of the filtering rig(pumps, housings, fittings and what not) instead of just buying more filters(that you would buy for the filtering rig anyway)
Anyway took enough of your time on this one(This is my first MV so hope you guys understand)
