M105a2 trailer to haul a S250 radio shelter..?
islandguydon
783
Michigan
I currently have a 1.5 ton M105A1 trailer, I just got a S250 radio shelter made to go in my M1028, My question is the bed for the trailer is the same dimension of the truck bed, has anyone ever seen a shelter carried around on a trailer....?
uscgmatt
13
Cordova, Alaska
I have used my m105 sometimes for the s250. but the only thing to tow it is the deuce and up.
Pinz25086
31
Orlando Fl.
The trailers in all of the pictures are M105's. The S-250 will not fit into a M101a1 or a2. I think that it may go into a3 because the wheel wheels are different. Mine sits in a M105 and it really works nice as a weekend camper. Put a small window A/C in it and you will be able to sleep well in the FL heat.
13 MIKE
MI
I don't have pics, but i have my S-250 in a M101A3. Works great. I stayed in it for the Findlay show.
KsM715
142
St George Ks
Well I had a couple of 101 genset flat bed trailers (w/o gensets) on my watchlist just for mounting the shelter to. But it seems they have been pulled. :x
islandguydon
783
Michigan
I figured on pulling the M105A1 with the shelter on top, bolted to the trailer. I pulled this trailer from Denver to Michigan with my m1028 pintal hitch, I reinforced the rear bumper and frame. Since the weight is even over the trailer Axel I feel I could pull the shelter to California if I had a mind to. What is the groups opinion..?
Don
timass1
Putnam/Ct
Truck looks good, I don't think you will have a problem with it like you said if you center the load over the axle. Plus that will give you about a foot of storage in front of and in back of the shelter. keep us posted.
The high center of gravity, on the M105 with S250, may make for a wild ride. If you do not get enough tongue load it will want to play crack the whip, on down hill grades. It would be a bad feeling to have that trailer come past you.
So, just buy a Deuce.
uscgmatt
13
Cordova, Alaska
Don
Pulling it is easy with the trucks...emergency stopping on the other hand:roll:. I had a lady cut me off while I was towing an empty 105:evil:. I hit the brakes And it got hairy. I was using my diesel F-250 going about 45.
And Timass1 i'm dieing to see some pics of the inside of your s-250.
