M916-920 Windshield wiper blades
jamboly
Brenham, TX
Does anyone know where you can get wiper blades for an M916-920? Is there a conversion to civi blades that will work. My blades are 18 in,
Beerslayer
55
Tualatin, Oregon
I replaced them on my M915-A1 - they're 18" ANCO STK NO. 51-18.
I took this ANCO number to NAPA and they couldn't cross reference it. I gave them the blade and they came out with the exact replacement, and it works great.
NAPA Part No. 60-1450 as marked on the package.
In their system it is WIP 601450
JH1
Seattle, WA
M915 windshield wiper: civilian equivalent
I looked at the NAPA item and it is a 14" long wiper. The M915 uses 18" wipers and it is their part number: WIP 601850 for $5.99 each. I can live with that.
Jim
simp5782
Feo, Fuerte y Formal
9,384
Mason, TN
Bump.
Be creative. Any blade with the simple quick connect slide lock works.
Remove center plastic slide lock, grind down each end of center support pin thru the wiper and remove it. Install over existing wiper end. Install longer M6 bolt and lock nut. Tighten.
I use rainX or Bosch blades. 16, 17 or 18in works
silverstate55
Unemployable
2,075
872
UT
Excellent Wes! And replacements probably available at most Walmarts or auto parts stores across the country...
Very nice! (y)
