need help fuel problem!
jrobinson5093
jakin georgia
my deuce will go about 10 miles then it will start buckin like it was runnin out of fuel, it will shut down it a few secs. The fuel return line are all empty. i though it might have been the filters where clogged up. I put new ones in today and it did the same thing. i pulled over and all the lines had no fuel in them again i let the intank pump run until oil come out of the bleeder screw then it fired right up and ran fine, does any one have any ideas what it could be causeing this. o and i run 100% wmo have been for while now. i flush the lines and run a tank of gas or diesel through it from time to time this is the first time the truck has givin me any problems. it has done this every time i drive it now.
3dAngus
101
Perry, Ga.
How much fuel is in your tank. Make sure it is at least half full, try again.
If it works, it might have an air leak in the in tank fuel pump.
Next...
doghead
4 Star General /Moderator
1,179
If you are not broken down on the road away from home, please mello out your title some. We need to reserve the dramatic titles for real emergencies.
ODw/envy
Deltona, FL
Sounds like a lift pump or fuel pick-up issue to me. You can't totally rule out the IP, though, until you trouble shoot the rest.
Dito on the title. Thought maybe you were stranded.
kennys@wi.rr.com
23
Waukesha, WI
I have ran WMO but never just WMO. I would think it's gotten to the point of being too think for one of the pumps. I would start by thining it out with diesel, bleed all your fuel lines and then start it and make sure all the injector lines are carrying fuel. If the problem persist after that check the hydraulic head. I had mine go and had to rebuild it. Also did you check the intank hose on the pump? There was a member here not long ago that had that hose rot out. WMO is more acidic than diesel so that is something to look at also. Doesn't take much of a hole and no fuel will make it out of the tank. Best of luck to you.
hoop
14
va
You are sucking air at your primary filter.
Clean the bolt seat, put in a new can gasket and tighten the poop out of it.
jrobinson5093
jakin georgia
I was stranded. I have noticed that it does it alot around half a tank. I do believe it is a air leak. Sorry I tried to change the title but dont know how. I will pull the pump out and go from there.
doghead
1,179
Is your tank vented or your cap vented? Have you tried to loosen the cap and run it?
btw, I edited the title. Your not on the brokedown road now, right?
jrobinson5093
jakin georgia
I pulled the pump out and the screens on the pump impeller were full something i didnt expect, leaves pecan i think. I think some one has done this to mess me up there was several hand fulls in the bottom of the tank. o and the shims and bottom of another pump.
doghead
1,179
Sounds like you found your problem! Great, sort of...
DieselBob
15
Arnold Maryland
Do you still have the strainer in the tank filler hole. I have made a habit of trying to remember to take the filler cap off and just give a quick check for anything that doesn't look quite right. Lower fuel level than expected, spilled fuel around the filler opening that wasn't there before. Now a days you just never know.
