Capt.Marion
- 15
- 38
- Atlanta, GA
Looking good! I like that desert M37 behind the 757.
Yes Ryan, there is already a crossmember behind the seats to support a tonneau type cover (sort of part of the original cabtop).rmgill said:Bjorn, have you thought about adding and additional set of tubing to give the back of the cab more cover so you'd have more usable storage space you can reach from inside the cab?
Finally got started on the cover for the rear of the cab. Using pieces from an old 5-ton cargo cover and "Goop", it should be finished in a few days.Bjorn, have you thought about adding and additional set of tubing to give the back of the cab more cover so you'd have more usable storage space you can reach from inside the cab?
Still holding up well considering that only silicone glue ("Goop") was used and the eyelets. Had the top off a couple of times and no problems.Old thread, but I love what you did with the printer cord Bjorn. I may just make the soft top for my M220 instead of getting a repro. Was wondering how one would go about making the rope/cord lip that slips into the windshield groove. Great idea!
