yolner
- 68
- 28
- Rockville, MD
I had some issues with hunting idle so I decided to check the in-tank pump/hose. Pulled the pump. Replaced the hose. Cleaned the screens. Reconnected all the fittings.
Drained old diesel and put in 20 gals of fresh.
Also had a leaky fitting on the IP after I installed the westfolk fuel filter kits. Pulled that fitting and put some gas rated teflon on the threads and reinstalled the plastic fuel line into it.
Finally, turned the idle screw in a bit while I was in there to raise the idle.
After all this, the first time I went to start the truck it started up but the idle was up and down. I shut her down to go look what I did wrong. Didn't see anything obvious. Went to start it back up and crack crank nothing. Tried a few more times and it just won't start. Before this it started first crank.
I went over everything I touched about a dozen times and I don't see what I could have done to make it quit starting. I need some new ideas before I push it off the nearest cliff![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
