samsimpson
- 0
- 0
- Corpus Christi, TX
I have searched but can't find the actual size. I think it is 1 1/4" but want to make sure before I pick some up. Thanks.
No other fuse/cb in that circuit. Wired from the accessory switch, which is wired to the battery (+) terminal indirectly, but without protection.Some DON'T have a fuse under the cover? then is the power to the pump protected elsewhere?
A simple search for slo blow, would have been helpful.
Simply reading the thread would of been even more helpful to the "do a search" trolls. I already stated I tried that.
Since I posted here last, I thought about that very idea and did it. It took a few minutes but it worked! I looked in the -20P, looked at the pictures until I saw the fuse! then googled the part number. Found it in about the 3rd link I looked at, including the length of the fuse. I guess it's all about persistence and determination.As a matter of fact you could have looked in the Tech Manual for the part number and crossed referenced it to find the size.
No need to get huffy puffy, I wasn't calling you a troll directly. I did an advanced search and yes I got a ton of posts returned for slow blow and yes I did alot of reading. I did not find the length, which is what I was asking about.I am a moderator, not a troll. I teach, not hand feed... If you do a search (advanced is even better) for "slo blow or slow blow", you will find your answer(I told you what to search for, not knowing if you knew the correct key words). I have posted the detailed information before, so I know it's in the forums.
If you call me a troll again, you'll get some time off.
Are you freaking serious? So people have to directly say they searched on the forum for you to understand that.You never said where you searched. Wally World, Big Lots, your back pocket, etc.
The more info you give us, the better we can help.
A word of advise. Don't mess with Doghead. He does bite.
ThanksHere is the simple answer, the spec sheet...
(If you don't like the search function on the site, go to google, enter keywords plus steelsoldiers)
