- 3,861
- 2,470
- Hiawassee, Georgia
I have an M35A3 and have installed an M66 ring mount. All M35A3s come with the large cab reinforcement plate already installed. However, my A3 also has a top reinforcement plate the covers the rear top of the cab. As you can see in the photos, there is no room between the poles and the rear of this reinforcement plate for the soft top to be installed. I have seen similar plates on at least one five-ton and on all A3s. I also remember reading some M66 mounting instructions several years ago for the 5-ton (Marines) that mentioned installing the top reinforcement plate, but didn't have any diagrams. Obviously, this plate adds strength to the cab and I hate to remove it. Optionally, I can cut two semi-circles out of the plate to provide spacing between the plate and the two rear support poles, but I hesitate to do this. This is not covered anywhere in the TM that I can find. Is there a different top reinforcement plate to be used with the M66 ring mount? Has anyone else encountered this problem?
